Forum Home Forum Home > FrameBuilder MRD > Support
Forum LockedSupported Machines
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: Supported Machines
    Posted: 31 May 2019 at 11:56am
Exports to the following machine manufacturers are supported.
Howick
www.howickltd.com
Pinnacle
http://www.pinnaclelgs.com/
FrameMac
www.framemac.com
FrameCAD Structure
www.framecad.com
Xiamen Xinhonghua Machinery
www.cold-roll-former.com/about-us
XXH-5S
BOSJ
UNBAK
Dahezbforming
Edited by administrator - 16 Jan 2021 at 11:33pm
BAF Group View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BAF Group Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2021 at 11:21am
Dear All,
Hope you are doing well,
We are using LGS Machine C89 profile by LiMing Stamping Form Machine Co.,Ltd their website in kink below:
There machine compliance with Vertex bd 2019 version. Also I will share one of CSV file for CNC output.
I tried to use CSV files that generated with machine listed in MRD but it make crash in software.
I tried also to modify CSV files but it doesn't work.
Kindly, give me solution if that available.
CSV file work with machine:
DETAILS,,æ°â€˜Ã¥®¿3
COMPONENT,E2-A,HX89-0.80,STUD,INVERTED,1,224.40,20.50,231.83,20.50,7.43,41.00,DIMPLE,17.70,SWAGE,27.50,DIMPLE,206.70,SWAGE,213.70
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,292.05,224.35,70.43,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,812.00,224.35,590.38,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,1331.96,224.35,1110.34,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,1851.91,224.35,1630.29,14.90,41.00,END_TRUSS,-0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,2371.87,224.35,2150.25,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,2891.82,224.35,2670.20,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,3411.78,224.35,3190.16,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,3931.73,224.35,3710.11,14.90,41.00,END_TRUSS,-0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,4451.69,224.35,4230.06,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,4971.64,224.35,4750.02,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-B,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,5491.59,224.35,5269.97,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,330.41,224.35,552.03,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,850.36,224.35,1071.98,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,1370.31,224.35,1591.94,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,1890.27,224.35,2111.89,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,2410.22,224.35,2631.84,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,2930.18,224.35,3151.80,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,3450.13,224.35,3671.75,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,3970.09,224.35,4191.71,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,4490.04,224.35,4711.66,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,5010.00,224.35,5231.62,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-C,HX89-0.80,DIAGONAL BRACE,INVERTED,1,304.94,5529.95,224.35,5751.57,14.90,41.00,END_TRUSS,0.00,DIMPLE,14.89,SWAGE,27.50,SWAGE,41.93,SWAGE,263.01,SWAGE,277.44,DIMPLE,290.05,END_TRUSS,304.94
COMPONENT,E2-D,HX89-0.80,BOTTOM TRACK,NORMAL,1,5822.00,0.00,25.13,5822.00,25.13,41.00,LIP NOTCH,14.10,DIMPLE,20.50,LIP NOTCH,58.12,DIMPLE,81.25,LIP NOTCH,102.15,LIP NOTCH,102.89,LIP NOTCH,519.57,LIP NOTCH,520.31,DIMPLE,541.20,DIMPLE,601.20,LIP NOTCH,622.10,LIP NOTCH,622.84,LIP NOTCH,1039.52,LIP NOTCH,1040.26,DIMPLE,1061.16,DIMPLE,1121.16,LIP NOTCH,1142.06,LIP NOTCH,1142.80,LIP NOTCH,1559.48,LIP NOTCH,1560.22,DIMPLE,1581.11,DIMPLE,1641.11,LIP NOTCH,1662.01,LIP NOTCH,1662.75,LIP NOTCH,2079.43,LIP NOTCH,2080.17,DIMPLE,2101.07,DIMPLE,2161.07,LIP NOTCH,2181.97,LIP NOTCH,2182.71,LIP NOTCH,2599.39,LIP NOTCH,2600.13,DIMPLE,2621.02,DIMPLE,2681.02,LIP NOTCH,2701.92,LIP NOTCH,2702.66,LIP NOTCH,3119.34,LIP NOTCH,3120.08,DIMPLE,3140.98,DIMPLE,3200.98,LIP NOTCH,3221.87,LIP NOTCH,3222.61,LIP NOTCH,3639.29,LIP NOTCH,3640.03,DIMPLE,3660.93,DIMPLE,3720.93,LIP NOTCH,3741.83,LIP NOTCH,3742.57,LIP NOTCH,4159.25,LIP NOTCH,4159.99,DIMPLE,4180.89,DIMPLE,4240.89,LIP NOTCH,4261.78,LIP NOTCH,4262.52,LIP NOTCH,4679.20,LIP NOTCH,4679.94,DIMPLE,4700.84,DIMPLE,4760.84,LIP NOTCH,4781.74,LIP NOTCH,4782.48,LIP NOTCH,5199.16,LIP NOTCH,5199.90,DIMPLE,5220.80,DIMPLE,5280.80,LIP NOTCH,5301.69,LIP NOTCH,5302.43,LIP NOTCH,5719.11,LIP NOTCH,5719.85,DIMPLE,5740.75,LIP NOTCH,5763.88,DIMPLE,5801.50,LIP NOTCH,5807.90
COMPONENT,E2-E,HX89-0.80,TOP TRACK,INVERTED,1,5822.00,5822.00,214.13,0.00,214.13,41.00,LIP NOTCH,14.10,DIMPLE,20.50,LIP NOTCH,259.59,LIP NOTCH,260.33,DIMPLE,281.23,DIMPLE,341.23,LIP NOTCH,362.12,LIP NOTCH,362.86,LIP NOTCH,779.54,LIP NOTCH,780.28,DIMPLE,801.18,DIMPLE,861.18,LIP NOTCH,882.08,LIP NOTCH,882.82,LIP NOTCH,1299.50,LIP NOTCH,1300.24,DIMPLE,1321.14,DIMPLE,1381.14,LIP NOTCH,1402.03,LIP NOTCH,1402.77,LIP NOTCH,1819.45,LIP NOTCH,1820.19,DIMPLE,1841.09,DIMPLE,1901.09,LIP NOTCH,1921.99,LIP NOTCH,1922.73,LIP NOTCH,2339.41,LIP NOTCH,2340.15,DIMPLE,2361.05,DIMPLE,2421.05,LIP NOTCH,2441.94,LIP NOTCH,2442.68,LIP NOTCH,2859.36,LIP NOTCH,2860.10,DIMPLE,2881.00,DIMPLE,2941.00,LIP NOTCH,2961.90,LIP NOTCH,2962.64,LIP NOTCH,3379.32,LIP NOTCH,3380.06,DIMPLE,3400.95,DIMPLE,3460.95,LIP NOTCH,3481.85,LIP NOTCH,3482.59,LIP NOTCH,3899.27,LIP NOTCH,3900.01,DIMPLE,3920.91,DIMPLE,3980.91,LIP NOTCH,4001.81,LIP NOTCH,4002.55,LIP NOTCH,4419.23,LIP NOTCH,4419.97,DIMPLE,4440.86,DIMPLE,4500.86,LIP NOTCH,4521.76,LIP NOTCH,4522.50,LIP NOTCH,4939.18,LIP NOTCH,4939.92,DIMPLE,4960.82,DIMPLE,5020.82,LIP NOTCH,5041.72,LIP NOTCH,5042.46,LIP NOTCH,5459.14,LIP NOTCH,5459.88,DIMPLE,5480.77,DIMPLE,5540.77,LIP NOTCH,5561.67,LIP NOTCH,5562.41,DIMPLE,5801.50,LIP NOTCH,5807.90
COMPONENT,E2-F,HX89-0.80,STUD,NORMAL,1,224.40,5801.50,7.43,5801.50,231.83,41.00,SWAGE,10.70,DIMPLE,17.70,SWAGE,196.90,DIMPLE,206.70
Bait Al Furat Pre-Fabricated Building
This page was generated in 0.143 seconds.
