Forum Home Forum Home > FrameBuilder MRD > Support > Tutorials
Steps on how to add an opening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mo78 Quote  Post ReplyReply Direct Link To This Post Topic: Steps on how to add an opening.
    Posted: 05 Jul 2018 at 8:19pm
Step 1:
Click the “select tool� icon which is on the left hand corner of the page.
Choose the wall on which you want to insert a window or a door.
With the select tool select the wall you want to insert an opening.
step 2:
Click on the window icon to add a window or Click on the door icon to add a door.
                                                OR
Go to Draw>Wall>Add Opening>Add a Door.
Go to Draw>Wall>Add Opening>Add a Window.
step 3:
This properties menu’s will pop up so select the correct width etc.
step 4:
Select the place where you want to place a window or door.
final result:
                                         OR
This page was generated in 0.129 seconds.
