How to Stop MLB The Show 26 from Crashing on PS5
NightFury View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NightFury Quote  Post ReplyReply Direct Link To This Post Topic: How to Stop MLB The Show 26 from Crashing on PS5
    Posted: 3 hours 13 minutes ago at 4:35am
Quick-Fix In-Game Settings
Some settings in MLB The Show 26 are more taxing on the PS5 hardware than others. Tweaking these can drastically reduce crashes:
  • Turn off Variable Refresh Rate (VRR): In PS5 settings, disabling VRR can prevent instability when the game is pushing heavy graphics, especially during pitching animations and base running.
  • Avoid heavy menu screens: Screens like Progress/XP paths, Collections, and Squad Builder are known to cause crashes after long navigation sessions. Spend less time lingering in these areas.
  • Access Moments from the main hub: Playing Diamond Dynasty Moments straight from the main menu is more stable than navigating deep into the game mode.
  • Disable Cross-Play: Online crashes sometimes happen due to server conflicts. Turning off Cross-Play in your network settings can minimize matchmaking errors.
Clear Console Cache and Rebuild Database
Temporary files and corrupted cache data are frequent culprits behind mid-game crashes. Rebuilding your PS5’s database can help:
  1. Completely turn off your PS5 (do not use Rest Mode).
  2. Hold the power button until you hear a second beep (~7 seconds).
  3. Connect your DualSense controller via USB.
  4. Select Clear Cache and Rebuild Database from the Safe Mode menu.
  5. First, clear the system software cache and allow a reboot, then rebuild the database.
This process cleans up corrupted temporary files and optimizes how your console reads game data, reducing the chance of freezes.
Fix Corrupted Files & Check Hardware
Even after clearing cache, crashes can be caused by corrupted game files or overheating:
  • Check for game updates: Highlight MLB The Show 26 on the home screen, press the Options button, and select Check for Update to ensure you’re on the latest patch.
  • Reinstall the game if needed: If you encounter a specific error code (e.g., CE-108255-1), deleting and reinstalling the game often fixes it.
  • Prevent overheating: The game is demanding on PS5 GPUs. Make sure your console has at least four inches of ventilation space on all sides. Clean dust from fan vents with compressed air to maintain proper airflow.
Additional Tips
  • Keep your PS5 firmware updated. System-level patches can improve stability.
  • Avoid sudden power-offs or forcing the game to quit, as this can create file corruption.
  • If crashes persist, consider running the game on performance mode instead of resolution-focused settings to reduce GPU load.
By combining these adjustments—tweaking in-game settings, clearing cache, and maintaining your hardware—you should experience far fewer crashes and a smoother MLB The Show 26 session on PS5.
This page was generated in 0.195 seconds.
